16-Channel Support in Basics Station Mode
RAK LoRaWAN® gateways support up to 16 LoRa® channels in Basics Station (BS) mode, enabling reliable, high-capacity communication for dense IoT deployments.
This guide walks you through connecting your RAK gateway to Actility ThingPark, verifying the connection, and troubleshooting common setup issues.
Before you begin, make sure you have the following:
  • A 16-channel RAK LoRaWAN gateway (RAK7289V2/RAK7289CV2 WisGate Edge Pro V2 is used in this guide)
  • Gateway firmware (WisGateOS 2 v2.2.14 or later)
  • A connected LoRaWAN Network Server (LNS) with 16-channel support in Basics Station mode
  • An internet connection for the gateway via Wi-Fi, Ethernet, or cellular
Connect the Gateway to an LNS
This example uses Actility ThingPark as a reference. You can follow similar steps for other LNS platforms that support 16 channels in Basics Station mode.
  1. Log in to the Actility ThingPark Admin Console.
  2. On the Dashboard, click the “+” button under the BASE STATIONS tab to add a new gateway.
Actility Dashboard View
Figure 1: Actility Dashboard View
  1. In the ADDING A BASE STATION prompt, click View More Manufacturers to see the complete list of gateway vendors.
Add a base station in Actility
Figure 2: Add a base station in Actility
  1. In the Select Your Base Station Manufacturer window, search for and select RAKwireless. Either scroll through the list or type RAKwireless in the search field.
Search for RAK as the manufacturer in Actility
Figure 3: Search for RAK as the manufacturer in Actility
  1. You will be redirected to the ADDING A BASE STATION page. Fill in the required gateway information.
Enter the required base station information
Figure 4: Enter the required base station information
  • Model
    Select your RAK gateway. If it's not listed, choose the closest match based on your WisGateOS version from the table below.
RAK Gateway
Gateway Model Selection
RAK7240V2 Edge Prime
WisGate Edge Pro (RAK7289 V2)
RAK7285 Edge Ultra
RAK7289V2 Edge Pro
  • Name: Enter a name for your gateway.
  • LLR-UUID: Enter the gateway's identifier in the format 0016C0-XXXXXXXXXXXXXXXX, where XXXXXXXXXXXXXXXX represents the gateway's EUI. The EUI can be found on the gateway's physical label (GW EUI) or under Dashboard > Overview in the Web UI.
  • RF Region: Select the appropriate frequency band for your deployment region. To enable 16-channel operation, ensure that the selected RF Region plan supports 16 channels in your LNS.
  • Additional Information: (Optional) Add notes or comments for future reference.
  • Position: Set the physical location of the gateway by:
    • Typing the address into the Search field.
    • Clicking on the map to place the marker, the latitude and longitude fields will be filled automatically.
    • Enter the gateway's installation height (in meters) in the Altitude above sea level field.
If your gateway has a built-in GPS/GNSS module, there is no need to manually set its position. The gateway will automatically report its location to the Actility LoRaWAN server.
  • Connection Status Alarm: Sets the time and severity level for triggering an alarm when the gateway loses connection.
  1. Once all fields are complete, click ADD. A confirmation will appear; then click VIEW THE BASE STATION.
Confirm to add base station information in Actility
Figure 5: Confirm to add base station information in Actility
  1. You will then be redirected to the gateway's dashboard, where the status will initially display as INITIALIZATION.
Actility base station device dashboard
Figure 6: Actility base station device dashboard
Configure the Gateway
This section explains how to configure your RAK gateway to connect to the ThingPark platform via Basics Station (CUPS).
For a more detailed explanation of how to configure Basics Station on your WisGateOS 2 gateway, refer to the official WisGateOS 2 Basics Station configuration guide.
  1. Log in to the gateway's Web UI.
  2. Navigate to LoRa® > Configuration, and set the Work Mode to Basics station.
Select the Basics station in the WisGateOS 2 Configuration tab
Figure 7: Select the Basics station in the WisGateOS 2 Configuration tab
  1. Click Configure Basics Station server setup to begin the configuration process.
Setup Basics station server in WisGateOS 2
Figure 8: Setup Basics station server in WisGateOS 2
  1. Enter the following details:
Configure Basics station server parameters in WisGateOS 2
Figure 9: Configure Basics station server parameters in WisGateOS 2
  • CUPS Server
    Select CUPS Server.
  • Server URL: https://community.thingpark.io
    For other ThingPark instances (e.g., Enterprise or private deployments), use the CUPS URL provided by your network administrator.
  • Server Port: 443
  • Authentication Method
    Select TLS Server Authentication.
  • Trust (CA Certificate)
    Download the AmazonRootCA1.cer file and upload it.
Upload the Basics station server CA Certificate in WisGateOS 2
Figure 10: Upload the Basics station server CA Certificate in WisGateOS 2
Verify Gateway Status
  1. Return to the ThingPark Admin Console.
    If the configuration is successful, the gateway status will change from INITIALIZATION to ACTIVE within a few minutes.
No traffic or connected devices will appear until end devices are added and start sending data.
Active connection display on the Actility dashboard
Figure 11: Active connection display on the Actility dashboard
  1. Navigate to Dashboard > LoRa® statistics. Verify that the channel usage statistics chart shows 16 channels.
WisGateOS 2 LoRa Statistics active connection
Figure 12: WisGateOS 2 LoRa Statistics active connection
Troubleshooting
Issue
Possible Cause
Solution
Gateway Offline Incorrect Gateway EUI (LRR-UUID) Ensure the EUI in ThingPark matches the one displayed on the gateway label or Web UI, including the required 0016C0- prefix (e.g., 0016C0-AC1F09FFFEXXXXX).
Wrong gateway model selected Confirm that the selected model corresponds to the actual WisGateOS version.
Gateway not connected to the Internet Check that the gateway is online via Wi-Fi, Ethernet, or cellular connection.
Connection blocked by firewall Ensure that outbound traffic is permitted to community.thingpark.io on port 443.
Stuck at INITIALIZATION EUI mismatch or configuration not saved properly Verify EUI and model. Re-save the config, then wait a few minutes for the status to update.
FAQs
  1. Do I need to manually set the LoRaWAN region on the gateway?
    No. When using Basics Station (CUPS), the region is configured automatically by the LNS.
  2. Can the gateway automatically report its location?
    Yes. If GPS/GNSS is enabled on the gateway, it will automatically report its position to the Actility server.
  3. The gateway is ACTIVE, but I don't see any device data, is this normal?
    Yes. Device traffic will only appear after end devices are registered and actively sending data.
  4. Why does my gateway only show 8 channels in Basics Station mode?
    In Basics Station mode, the number of channels is determined by the LNS frequency plan. If your LNS is set to an 8-channel plan, the gateway will only operate with 8 channels.
  • Version 1 - How to Enable 16-Channel Support on RAK LoRaWAN® Gateways in Basics Station Mode
    • Date Published: 10/30/2025
